Hi all-- so after reading on here about the saint-- i pulled the trigger and got one... It does seem very well made-- but i am finding a problem and wanted to get your input before starting to work on a solution.. The on/off switch seems to be too stiff.. ON the left side of the headlamp is the level (up and down) adjust.. On the right side is the on/off adjust knob... You turn it on by rotating the knob on the right -- problem is-- its so stiff it just moved the lamp up and down.. I have to hold the lamp with my left hand in place and then use the right hand to turn it on.. Will this loosen up? It seems like the adjust on the left should be stiffer to hold the light in place while you turn it on.... Any thoughts?
