Ra Clicky Driver Current
adnj
With the three maximum OTF lumen ratings of the Ra Clicky, what is the maximum driver current for each:
  • 120
  • 140
  • 170 (Available direct from Ra Lights only
It's my understanding that all the clickies use the same driver, and Henry manually bin's his LEDs by efficiency.
Then each clicky is assigned a LED that's efficiency will match it's intended output and then after assembly the driver is manually calibrated to produce that specific lumen rating.
Because of all this calibration, the actual current output of each driver could vary a fair amount from 1 light to the next even in the same series model.
