Enzo Morocioli
Enzo Morocioli,
You can program one setting per entry into customization mode. This was done to keep the customization interface as simple as possible. The assumption is that you are going use the flashlight for a while and then tweak one setting, use the flashlight some more and then tweak again if necessary. Once you have finished optimizing your flashlight for your tasks, you will not need to change the setting again unless your needs change.
Ah that makes sense, thank you...
A possible improvement while maintaining simplicity would be to have the customization mode not exit when switched to high, but instead assign the output to the level chosen and wait for the user to switch back to low, where it would begin stepping the brightness down, waiting for the user to pick an output and assign it to a level. When the user is finished they can switch the Twisty off to exit customization mode.
It's just a thought... As it is now, I accept the method you chose.
Thanks again.
