Got my Raidfire today! Pretty cool light. I'll try to get a review up tonight.
So the initial testing puts this right up there with the DBS. My DBS still has a SLIGHT edge on the lux meter. I'm getting around 25,000LUX from the Raidfire, and around 25,500LUX from my DBS. Virtually indentical. They are similar in size, I'll get pics of them side by side.
now, i'm not sure if the Raidfire is upgradable, so it maybe as good as it's going to get until another model is released. If that's the case, it will probably be left in the dust by the DBS in the coming year.
Some quick observations, it's a thrower, that's for sure, should out throw a Tiablo A9 since it's competing with the DBS. Te tail cap is mushroomed, allows for stable tail standing, but some may find it a lot of material to get their thumb around.
Takes 18650's only from what I can tell, fine by me.
The low is LOW. Would hopefully be good in an emergancy situation where you need long run times, will look forward to other's run time tests.
Switching between HIGH and LOW is easy, just a little twist of the bezel, allowing you to signal in either HIGH or LOW with the forward clicky.
The reflector looks deep. I think my DBS produces a slightly small spot. Much testing still needs to be done.
The markings (labelings) is a bit over done on the Raidfire and Nitecore. If anyone finds a good way to remove it, let me know.
