[ QUOTE ]
gadget_lover said:Cool! DO you remember the text or source of the 100MPH design criteria? I've not been able to find anything but assertions.
[/ QUOTE ]
I'm having trouble finding stuff online myself, but I remember distinctly reading this and hearing it when I was younger. As KC2IXE asserted:
[ QUOTE ]
That said - I believe you are right that the design speed for most was in the 80 mph range, although MANY were designed for
a LOT more.
[/ QUOTE ]
My emphasis on "a lot more", especially if you're going by curvature radius. Some roads have curvature radii of 3000 meters or more nearly everywhere. This evidently means they were ultimately planned with very high speeds in mind once automotive technology caught up.
You might find
this interesting. Here are some of the more interesting points of the article:
1.
Uniform design standards called for design speeds of 70 MPH, lanes 12 feet wide, gradients not to exceed 6 percent and bridge clearances of fourteen feet. [5] As people who drove the system when it opened know, the speed limit, with very few clearly marked exceptions, was 70 MPH.
2.
The report showed that lowering speed limits by as much as 20 MPH or raising speed limits as much as 15 MPH had little effect on driving speeds. They found that lowering speed limits below the 50th percentile did not reduce accidents but did increase driver violations. They found that raising posted speeds did not increase speeds materially or increase accidents.
3.
Studies show that the 85th percentile is the safest speed limit. However, the 85th percentile is not a fixed speed. It may be that the comfort speed level increases with time and the 85th percentile increases accordingly.
My comments: The 70 mph design speed was based on automotive technology of 50 years ago, and it was considered to be the absolute minimum speed for which any Interstate highway should be designed. Most were designed with the "mythical" 100 mph speed in mind, or could easily be converted to such standards by realigning curves and lengthing on-ramps. Also note that #3 supports my assertion that as automotive technology improves the so-called 85th percentile actually increases. I remember in the late 1960s most drivers drove at Interstate speeds in the 65 to 80 mph range. Nowadays you'll see somewhere in the 80 to 90 mph range on many of the same roads. What happened is that cars have gotten more stable at higher speeds thanks to better engineering. If not for SUVs, I think 85th percentile speeds might be close to that magic 100 mph mark on many roads.
[ QUOTE ]
Lets see. that means the frontal area shrinks to about 4 foot high by 5 foot wide. Now
that's a seriously small car. I'm not sure you will fit 4 adults comfortably into that. You could make it 6 foot wide and 3.3 feet high, but my back would not allow me to climb into it.
A Prius is reasonably slippery. It's got a CD of .26 The Honda Insight is .25. The Ferarri appears to be in the .3 range. The 2005 corvette is .28 I've never heard of a production car with a CD as low at .1 What shape does it take to get a cd of .09? Would that shape be drivable?
[/ QUOTE ]
Think of something like those bullet bikes but wider for a Cd of 0.09. You can have Cds way lower, but the vehicle wouldn't be driveable. Also, if we can get laminar flow (which increases with V instead of V²) instead of turbulent flow there will be an even larger drag reduction. To put things into perspective about how far we can go, we have made vehicles which can exceed 80 mph on human power alone. Many, including myself, think it is possible for one of these vehicles to break the century mark. If so, designing a 4 person car which gets 100 mpg at 100 mph would be a fairly simple exercise. And small, low vehicles can be made easy to get in and out of by simply having built-in jacks which lift them a foot or so off the ground when they're parked. 20 ft² is higher than you mentioned because the tires add about 9 inches to the height without much frontal area. The roof would probably be about 4 feet high for a car that's 6 feet wide, not the 3.3 feet you said, Your back will be fine, especially with the "lifts". /ubbthreads/images/graemlins/wink.gif It seems almost asinine to waste gas on a big, tall SUV mostly because it's easy to enter or exit. I won't even get started on what I think of the physical condition that most people in this country are in that entering a low vehicle should even be an issue unless you're over about 75. Putting aside this topic for a moment, I really would like to see more people walking and biking to their destinations instead of driving. Driving is one reason we have so many people in such bad shape at relatively young ages.
[ QUOTE ]
Can you actually drive a car safely at 100 MPH with the super stiff compounds in the ultra low rolling resistance (ULRR) tires? I have low rolling resistance (LRR) tires on my car and they are not the best in terms of handling and stopping.
[/ QUOTE ]
Why not? Remember what I said about banked curves? You can bank enough so that the forces are neutral at whatever speed you choose. Under those conditions, as far as the car is concerned, it's going in a straight line (just with a little more weight from the resultant of the cornering force and gravity). You can theoretically take such a curve on glare ice with no problems (not that I would try it). Believe me, the difference between ULLR and regular tires isn't that significant unless you drive right at the car's limits, and you shouldn't do that unless you're at a racetrack. As for stopping quickly, why not design cars with air brakes which supplement the wheel brakes? These would be surfaces which pop out so as to dramatically increase drag whenever emergency braking is applied, and they would be very effective at high speeds. Do you see a trend here? For every problem you can come up with there is an engineering solution. /ubbthreads/images/graemlins/wink.gif
[ QUOTE ]
Most of the accidents happen when a car changes lanes or while merging. I don't have the figures but recall it was a very high percentage. You are begging for accidents when you have incoming traffic 30 mph slower than traffic. In my experience, most cars don't even get up to 65 by the end of the on-ramp so the speed differential is even higher.
[/ QUOTE ]
Make the on ramps longer. Where you can't, lower the speed limit in that area. I agree 100%. Speed differential, not speed, causes accidents.
[ QUOTE ]
The accidents chronicled in the daily news tells me that the roads are not very safe at 65 MPH. They might be if, like railroads, the traffic was strictly controlled and following distances were enforced, but we are talking cars and streets and human drivers.
[/ QUOTE ]
Ultimately, I feel we should move to automated cars for many reasons, not just to increase speeds (although that alone would make it worthwhile). In the mean time, we can do a lot more to increase safety and speeds. I think racing car type harnesses and roll cages should be required equipment on all passenger vehicles.
[ QUOTE ]
Hmmmm Speed Nazi. You get dragged away when you speed? OK.
[/ QUOTE ]
Just a term I've heard. I don't like when people who know nothing about a subject start talking in absolutes, as in 80 mph is always unsafe, or 55 mph always is. The fact is that given enough money and incentive, you can design roads and cars to be safe at any speed within the limits of the technology (which I would put at roughly 150 mph for mass-produced vehicles today). We already have many roads which would be safe at 100 mph (or even more). Why not use them as such, even if it means we have to restrict which vehicles can use those roads (by all means exclude SUVs)? Remember that driving is a privilege, not a right, and the state can set whatever standards they wish for both motor vehicles and drivers. I would rather those standards be high enough to exclude marginal cars and drivers. That alone would make higher speeds and fewer accidents almost a given.
About the "radar" defense, I don't think it would hold. /ubbthreads/images/graemlins/grin.gif
