Found a PR base bulb lying around. Marked on the base is "GE KPR141". Decided to try it in a 2D flashlight I also keep lying around loaded with two Nicd's. Result? Nearly as bright as my Tec40.
(no kidding ... ) Found out why when I found this info on the web.
http://www.donsbulbs.com/cgi-bin/r/t.pl
KPR141 bulb specifications:
category: Miniature
volts: 2
amp/watt: 1.2A / 2.4W
base: P13.5s - Single Contact Miniature Flange
glass: B-3-1/2
filament: C-2R
m.o.l.: 1-1/4 inches
l.c.l.: 1/4 inches
notes:
Xenon
So, this lamp draws 1.2A at 2 Volts. The Nicad's are 4000 mah's from Hosfelt. So the bulb is being overdriven by 0.4V. Bulb should be 1.66 ohm for 1.2A @ 2V, and the Nicd bats' should be able to deliver (I guess) the full resulting amperage of
1.45 for almost 3.5 W ... If bulb life suffers too much, seems like a good application might be an incandescent light with smaller (AA or AAA) rechargables for power?
category: Miniature
volts: 2
glass: B-3-1/2
filament: C-2R
l.c.l.: 1/4 inches
notes:
Xenon
