Well, this happened once in cold weather a while back, and it just did it again in the cold. When the temps get below about 40-45 degrees F, and I try to turn the headlamp on from a cold start, the white LED will not turn on. Click once, red. Click twice, blue. Click a third time, it turns off. It just toggles between red and blue, and the red seems to be a much dimmer than normal brightness with a distinct PWM-type flicker. But if I leave either the red or blue LED on for a few minutes, the white LED lights up and the light cycles through it's modes normally until I turn it off and let it soak in the cold some more.
Clearly something in this circuit does not like cold. It's not the LED itself, since when it acts up and I go to the next click after blue (when the white should come on), the light turns off, but another click after that does not reveal more darkness. It goes straight back to red. IOW, there is no extra empty space in the modes. It's red-blue-off-red-blue-off. Not... red-blue-off-off-red-blue-off-off. Dig? Anybody else experienced this while using the ROV headlamp in the cold?
