Renard DellaFave to mail
The information did include a question.
I would, at a minimum, request that the technical team get back to me about: are 500 and 1000mA discharge rates within the cell's ratings or not?
On Jan 7, 2008 9:59 PM, New Excite Shop <
[email protected]> wrote:
Dear Renard,
Thanks very much for your valuable information. We will pass the your
information to our technical team about the issue. Thanks again for
your support.
Regards,
UltraFire-Shop
On Jan 8, 2008 3:19 AM, Renard DellaFave <
> Hello, I'd like some information regarding the 10440 LiIon batteries I
> bought from your company.
> First, I have tested all four on a UBA-4 battery analyzer and get capacities
> of about 300mAh on each (200mA load) -- they are labeled 500mAh.
> If they are mis-labeled or over-represented, I actually do not have much
> problem with that.
> However, I have learned more about LiIon cells, and a drop in capacity below
> 80% for new cells can indicate internal damage, and these are at 60% _if_
> good ones would indeed test at 500mAh.
> Also, I would like a data sheet or other indication of max. rated discharge
> current, as I have been assuming 2C is OK and if not I need to know.
