Rechargeable equal to 3X123????????
2 x 17500 sometimes works depending on the light. Its slightly wider than cr123 but still fits most lights.
Pardon me if this is just stating the obvious, but BatteryJunction among others sells cr123 3.0v cells that you could use. I use them in a three cell cr123 light that has a Luxeon V and they work fine. That light eats batteries pretty fast, puts out alot of light - now I get 'free' lumens.
Yeah, if two 17500s will fit, that will give more usable power and longer runtimes, esp on higher drain lights, than 3x3.0V rechargeable cells. Those 3.0V cells are OK, but they are usually quite lacking in their stored power capacity. Two 17500s will typically run just as long as 3xCR123 cells which ends up being quite a bit longer than 2x3.7V R123 cells which is quite a bit longer than 2x3.0V 123 cells.
17500, like most rechargable lithiums have a nominal voltage of 3.7, but ~4.2 hot off the charger. The reason they work in place of 3xCR123's is their voltage sags much less than primaries, so they might stay at 8.2 under load, while each of the lithium primaries might sag .3 volts, so 8.1 total.
PYKE said:
Would those 2X17500 fit in a SF M3?
Ooh yes, free lumens :D
AW's protected 17500's will power up the MN11 with a single click for the first few minutes of run time
OK, so, who makes the best, and where can they be bought?
Matter of fact; i'm running this configuration right now!
You can run both bulbs (MN10, MN11), but you need to double-tap it with the MN11 (except when batteries are just of the charger).
I'm waiting for lumensfactory to come out with something just under 2.2amps for it, so i can get the most light without the hassle of double-tapping the switch, and without reducing the 17500's life significantly.
I use AW's batteries. He sells them in this thread: http://www.candlepowerforums.com/vb/showthread.php?t=140362
