I have Trustfire protected and Ultrafire unprotected cells from DX. So far, they are both good for the $$$. I have about 25 re-charges on the unprotected cells and roughly half that on the protecteds. I
NEVER fully discharge any of them. I run them for about 30-40 minutes in my 6P, knowing that over discharging can lead to cell-reversal and
. I did take a gamble once and ran some cells till' the Cree LED turned yellow-ish, just to get a MAX run-time figure (50 minutes). I carry at least 4 extra cells with me at work.
My charger is that gray DX-ultrafire, that cuts charge at 4.2 Volts for each cell independently. Its a great charger IMHO, it will not attempt to charge a cell that has been over-discharged and can't nominalize back up over about +2.7V. This is an added safety feature I think. I also have a 3.6 Volt NON-peak detect charger that I use only if I get a cell that can't nominalize back up to the lower threshold of the charger. Its only used for a minute, to get the cell past that lower point. So far I have only had to use it once, with one of the trustfire protecteds.
I am a bit retentive with battery maintenance. Its a carry-over from my involvement with RC car racing. so a bit of a warning from this point on. heres my procedure for unprotected cells...
When the cells are new, I give them a full charge to 4.2 Volts.
I connect my DX 6090 module to each raw cell and monitor the voltage with a digital multi meter. When voltage drops to 2.8 Volts I disconnect the battery, wait a half day, recharge and repeat the cycle, carefully monitoring battery voltage the whole time and cutting the discharge at 2.8V.
On about the 4th cycle, I time it with my stopwatch. I jot down the time in seconds it takes each cell to reach 2.8V. Cells are matched based on discharge time, and used in numbered pairs in my 6P.
I don't even bother with new protected cells, I just use them worry-free. I do sometimes monitor voltage when they are charging though.
So far, I have 8 cells in total and no duds... knock on wood.
Disregard the mAH ratings on any DX battery when RCR123 battery shopping, for the most part they are over-rated.
