yes you can, rcr123a are 3.7v cells, same chemistry as cells you charge now.
Actually, "RCR123A" is ambiguous, may be LiFePO4 3.2V or Li-ion 3.6V/3.7V 16340. I made a poor assumption, and so did you,
@alpg88.
Here's one example of 3.2V RCR123A.
Here is a more popular example of 3.2V RCR123A.
And here is an example of a Li-ion cell thats voltage is limited to 3V and yet still designated "RCR123A."
@olddogrib, you really have to look at the voltage printed on the cells themselves to see whether they say 3.6V, 3.7V or 3.2V.
Xtar ANT-MC1 Plus is a Li-ion charger only, which means it's only for charging 3.6V or 3.7V cells, which will terminate charge at 4.2V. LiFePO4 3.2V cells terminate at 3.7V which means that charger will overcharge LiFePO4.
It's pretty confusing, and most CPFers seem to refer to Li-ion 3.6V/3.7V cells as "16340.," often by chemistry, such as ICR16340, INR16340 or IMR16340. I assumed you meant 3.2V LiFePO4 because they more readily stand in for primary CR123A 3V cells where 3.7V 16340 cells may fry the driver or device.
If you can't tell by looking at the cells what the nominal voltage is, give us a picture of the cells, and CPF will figure it out.
