Led_Blind
Hi all
I am going to build a 3D m@g mod using a single seul led and the stock reflector and would realy like to regulate its output.
After researching drivers it seems i need a buck\boost, but not to sure. The other option is to simply use a boost circut and allow the led to be DD untill the Vf of the cells is lower than the led's Vf.
I am hoping for some advice here, ie will the 4.5v from alcaline D cells fry the led if direct driven, best solution, variable outputs etc.
