Recommend cheap driver board for LED 'lantern'
Daravon
My electricity went out recently. I have lots of flashlights, but I came to realize I ought to have a lantern-type light.
In my darkroom I have a red Cree screwed onto a CPU heatsink using a LM317 as a current driver. Using a 5v wall-wart this makes a great non-directional safe-light that lights up the whole room. I want to make something like this on the cheap with a white LED for emergency use.
Instead of using direct drive (low runtime) or a LM317 (inefficient) I would like to use a PWM driver circuit for more battery life and adjustable brightness. I would like "very low, runs forever" mode and a fairly bright mode. I could use a 6v lantern battery and a buck circuit, or use more-common AA batteries with a boost circuit. Maybe I could get a circuit that would work with practically any batteries, that way it would start boosting the battery voltage after it dropped below V_f? This sounds ideal to me but I don't know where to buy such things. I don't want to spend a lot either, or else I would just buy a ready-made lantern.
Hi, milkyspit makes just such a long life lantern in the home built / custom threads. It runs a heck of a long time on very little draw.
Another option for "ultra simple" is a 30 ohm resistor in line with a CR123 and a white LED. The draw will be down in the 5 - 10 ma range, similar to candle output. A quality CR123 will run an entire week of nights, and the 10 year life makes for a great emergency cell.
That's a great idea. I have more CR123s than anything else, and surely the lowest mode would be the most useful anyway. Would I want to use just about any Cree-type LED? I have some 10mm white LEDs around here somewhere.
