roll them? that is the deoxidation method i apply first, spin them around grinding the contact points together like grinding valves.
if that does not do anything then the parts and pieces themselves would have to be replaced or shunted.
There was a pictorial on shunting a Mag Spring with flexable copper wick wire , reducing the resistances by lots. People applying fat copper and direct soldering battery to battery. Many different designs for the whole package resistance have existed ,but the cell itself just to the next cell? what could you do, silver coat it?
when pushing mass amps via a high discharge or even a short, you see quick how many molecules of metal are actually making contact. in high discharge with poor contact the battery itself (and holders) will heat up at that point, so the quantity of the metal to metal contact is such that even with great conductive metals the quantity of the metals connected makes a difference. spread out the contact somehow?? silver conduction pen?
prime "point" conduction areas to make more contact, emeryboard grinding , while you can make a rough surface with sanding , the peaks of the rough surface will bend onto the tightly pressed item onto it. so when you squish the battery into the rough ground contacts the molecular mountains will flatten into the battery contact areas (so to speak).
i often use Silicon spray to keep contact points from being oxidised, while silicon oils are not conductive , it seems to be better than getting a layer of metal oxides (which are not conductive) between things. stubborn battery connection points like Mini-mags i have improved by cleaning then applying lightweight high solvent silicon spray for long term maintance of the contact points.
those "pro" gold contact sprays are used by some, i always assumed they were just de-oxidiser and silicon oil anyways.
When analising why they use Gold for connections when silver is a better conductor (and cheaper) i noticed that gold Squishes quite a bit, so it is not always about the conduction of the metal as it can also be how squishy it is
because you could squish the metal into having more molecules connect. Try impacting it with amalgum
Reducing the number of cell units. use 1-3 Big Fat cell items, or higher voltage cell items, i have a great dislike for Series anyway due to reverse charge situations during deep discharges, so i prefer not to use wads of batteries and prefer to use big ones instead.
or the opposite
Increase the voltage even more and reduce the amperage, its the amps that gets ya .
