Reflector Question
SRacer2000
I'm working on a KX2 mod. Is the McR-19XR the right reflector to fit the stock Cree??
The McR19 and 19XR work with the Cree.
XR version has a tighter hotspot.
Search for KL1-R mods (R for reflector)
I think McR20s were used back when Luxeons were in the heads.
If so a McR19XR may be loose.
The McR-19 is longer and slimmer than the McR-20, it has a different parabola. I'd check the dimensions of the TIR in the KX2 first.
bernie
I know the McR-20 doesn't fit. I had and extra from my KL1-R project. I've got some UCL-LDF lens coming I'll try that before I order the McR-19. Thanks for the help.
Check out the dimensions to the McR-19
and the McR-19XR- theres also a groove added
its there to bind 2 or more together with an o-ring
I took some beamshots cause beamshots are fun :lolsign:
First the McR19
Now the McR19XR
I like and use the non-XR verison with my A19 head.
Its got the smoother spot to flood transition IMHO.
I ordered 1 of each of the McR-19s types from the Shoppe. See what I like best. I still have a stock KX2 and a stock KL1 I could do something with.
The optic is 18.65mm or 18.56mm I forget. But I don't think it comes down on the led. So one of the McR-19s should fit.
Is that the diameter, or the length of the optic?
Do you happen to know the diameter of the board on which the emitter is mounted?
