Reinstalling Mag Switch
webley445
St. Pete, Fl.
Well it came out simple enough, but not quite wanting to go back in.
Any suggestions?
Also am gonna try boring it out some but don't have a lathe, any ideas?
thanks
AuroraLite
HK
Webley,
Was it a mag c or d? How about trying to take out the retaining ring with a screwdriver, and slid it up the tube?
Good luck?
DonShock
Belton Texas
Make sure the allen screw is fully retracted and that the bushbutton is all the way in. These are the only things I have had hang up the switch when reinstalling. The shaft on the pushbutton can extend itself if you don't have it pointing up when you insert the switch assembly back in.
I have read other posts where people mention using a brake hone in a drill to bore out the body without a lathe.
webley445
St. Pete, Fl.
AuroraLite said:
Webley,
Good luck?
D cell
will give it all a try, seems that the actual push butoon part on top [black] of beneath [blue] is hanging up
webley445
St. Pete, Fl.
I got finally.
Seems it all needs to fit just so.
didn't help that the switch button fell out/apart when turned upside down.
Guess i just had to get the components put together properly.
