arewethereyetdad
As a die-hard McGizmo afficiando, I truly believe one can never have too many. However, I like 'em clipless. Just never been a fan of clips. Even though McGizmo's clip design is the best of any light, I just can't have 'em.
Therefore, I usually remove them. Now, as you all know, the McGizmo Ti clips are attached to the packs by two round head Ti screws. If you strip 'em, you've got some work ahead of you. I speak from experience. Because they're situated side by side, and because they're round-headed, they are virtually impossible to remove, or even grab onto for that matter. So, if you're like me and want to remove the clip, here's what you need to do.
First, try to unscrew them the traditional way. I am pretty sure the bit size is 1/16. UPDATE: Use Thorp 1/16" (See Don's note, below, post #3). If you strip them, which is entirely possible, you will need to do the following: get a small square file and carefully file flat surfaces into opposite sides of each screw. Be extra careful to not let the file touch the body itself - just file the screw heads against the clip (I didn't care if I ruined the screws or the clip, of course). Once you have two filed flats grooved into each screw you can then get a grip, so to speak, on the screw head with your small pliers and slowly turn each one out. It definitely works, but it takes time and patience.
The great thing about all this is that, although you max out a pair of screws and a clip, you keep the body perfect so that, if you lose all semblance of sanity down the road and actually want to add a clip, you still can. :nana:
Just a little tidbit from a McGizmo geek. Thanks for reading. :nana:
