Testing diffusers
Post #103 dealed with various combinations of LED-types and wide angle reflectors. I came to the result, that the combination XR-E and Carclo 10170 without holder (bond to the board directly) give the best distribution to start with tests of diffusers.
The diagrams in this post here are normalized to the brightness of the bare emitter in the center (black curve). As in post #103 there are two different diagrams.
The first one shows the normalized brightness of all the eight combinations tested on a plane wall. The light source was 50cm spaced from the wall. The distance along the wall is given as percentage of this spacing; 0% means on axis and 100% means 50cm away from the center (this equals 90 deg full width angle).
The second diagram shows the according angular pattern.
Both diagrams show the pattern of the bare XR-E without any optics (black curve as a reference). The pattern of the bare XR-E is very suitable for illumination of the whole viewing area - but a bare LED glares extremely.
For each of these eight curves i took a photo with identical camera setting. The camera was 125cm apart from the wall with wide angle optic. The bearer will never encounter such a situation, because the patterns cover a very wide angle. You can see the linear distance along the wall at the folding rule (hard to read at 800x800) and the full witdth angles on the yellow labels (30deg, 60deg and 90deg).
This photo is for bare emitter and belongs to the black curve 'bare emitter':
The 2nd curve (light blue) is the combination XR-E and Carclo 10170 without holder (reflector bond to the board directly) similar to that one described in post #103 but with a plane clear uncoated glass lens in front of it.
This photo is for XR-E with Carclo 1070 and glass lens and belongs to the light blue curve 'clear glass':
The flatness on a plane wall is nice, but not suitable for walking in a cave. The edge is much too sharp and artefacts are visible. And the glaring is the same as with bare emitter.
Domed diffusers
I tested a Khatod PLJT 35/02, which is nearely clear. I cut it down to a spherical cap with 6,5mm hight. the remaining diameter is about 24mm. This cap neither reduces the glaring nor improves the light distribution dramatically. I was astonished, that this dome provides some collimating effect and concentrates the brightness to the center!
This photo is for XR-E with Carclo 10170 and clear PLJT and belongs to the reddish long-dashed curve 'clear PLJT':
I made many experiments with PLJT 35/02 and vapor of different bonding agents (also cyanocrylat), but it was not possible to get a defined and homogeneous mat finish. I also tied to sand the internal surface - not good. The best result was achieved with a cleaner polish as used in the household. With this domed diffuser no glaring is left, the light source is about 300mm².
This photo is for XR-E with Carclo 1070 and clear PLJT and belongs to the reddish short-dashed curve 'sanded PLJT':
Plane diffusers
Next I tested three commercial and one home made plane diffusers.
First I tested XR-E with Carclo 1070 and L2optics OPTX-1-DIF8, which is a clip-on device for their 26mm optics. I bond it with the polished side onto a clear glass lense with epoxy to achieve a stable front lens. So the light enters at the rough side, quite the other way round than intended use. The glaring is reduced but still annoys, the light source appears 10mm² subjectively.
The photo belongs to the greenish long-dashed curve 'OPTX-1-DIF8':
Next I tested XR-E with Carclo 1070 and Ledil Ledilstar P SUB, which is a clip-on device for their 35mm optics. I bond it onto a clear glass lens as explained above. The glaring is reduced very well (30mm² subjectively).
The photo belongs to the greenish short-dashed curve 'Ledilstar P SUB':
Additionally I tested XR-E with Carclo 1070 and a diffuser not looking frosted but structured: OPTX-1-016S from L2optics. The glaring is reduced dramatically (200mm² subjectively) but the loss - especially at higher angles - is dramatical too! This belongs to the alternatingly dashed greenish curve 'OPTX-1-016S':
At the end I tested a selfmade diffuser: XR-E with Carclo 1070 and a plane glass lens etched at the internal side facing the LED. The glaring is nearely absent (200mm² subjectively) and the loss is acceptable. This belongs to the not-dashed blue curve 'etched glass':
Conclusions
- A domed diffuser is much more difficult to produce and brings no real benefit as I thought before :-o
- Some 'diffusers' concentrate light to the center too!
- All diffusers I tested povide increasing losses at high off-axis angles.
- It is possible to compensate the losses of a diffuser in the range of full beam angle up to 80 deg by using a wide angle reflector: This costs higher losses outside this range.
- The angular pattern of a bare XR-E can be 'reconstructed' in the range -40 to +40 deg at a comparable level. But outside this range the 'reconstructed' pattern drops below that one of the bare emitter naturally. The etched plane glass is a cheap part for that.
I decided to use the combination XR-E with Carclo 1070 and a plane glass lens in front of it, etched at the internal side facing the LED. This will give a nice 'diffuse-light' when tilt down about 30 deg.
