Request suggestions on LED for project
joema
Nashville, TN
I want to beef up the LED in some solar-powered landscape lights I have. Just a simple little experiment. Looking for suggestions on best type of replacement LED.
The lights look about like this: http://www.siliconsolar.com/shop/catalog/Multi-Tier-Solar-Landscape-Lighting-p-51.html
During the day, a 2" x 1.5" solar cell charges 2x NiCd AA batteries. Then at night the batteries run a single white 5mm LED, which isn't very bright.
I measured the 5mm LED Vf at 3.0 volts, and drive current was 18 mA.
Is there a replacement LED that would produce more output using the same drive current and voltage?
Below is what the LED and circuit board look like:
somone did a FULL breakdown on efficiency at specific currents, and the 4die, called other names like SMJLED, was the most lumens per watt for the 5mm things, these 4dies are a bit bluish.
so if they were run at the SAME 20ma of juice, they would look brighter, each die would only run at 5ma , high efficent.
i THINK they even beat lumens per watt, at these very low rates, high powered leds like cree and seul. i tested a cree with 20ma and its about the same.
which brings up Phosphors :) and how short lived any 5mm led is.
say for example these things have already run for 625 days 8 hours a day, they would be at about 1/2 power. and if they were cheap china leds, that coulda happened a year ago :)
http://www.molalla.net/~leeper/ledlife.jpg
if you ran a high-powered led (like a lux or cree), at such low powers, chances are good you wouldnt notice any drop in output for 10-15 years, instead of 2. so depends on what is important too, low maintance, or todays output.
then some of these lights use Colored leds, with a SINGLE color , limited spectrum, the percieved color would be brighter , but no spectrum.
good examples of that would be a CYAN , which would light plants good, and still be the SAME voltage, Turquise and cyan type leds are very bright Looking.
another example is a Yellow led, but they are different voltages, a sick yellow color would match them sodium vapor lights well :)
just change the pattern, the spread, the appearance, by using 3 leds instead of 1, you will run the leds lower, and more efficient, and can aim the 3.
anything else i can think of would require SOMETHING somehow, like more solar power, along with more battery storage, and mabey some adjustements in a resister. so you increase the total MA the thing can do.
