I am assembling a uv light using the NCSU033A by nichia, and have a few questions about the resistor to use.
The led is a Rank Ua6PL, wich means a Vf of 3.4~3.6V at 500mA
when i direct drive it, using a single 3.96V 18650 it consumes about 0.82A.
when i use a 1 ohm resistor i get 0.27A.
This is measured at the led itself, using a 30$ MM at the 10A position.
As i understand it the resistance of the MM affects the amount of current passing through the led, what would likely be the actual current through the leds with this readings?
i would like to get around the neigbourhood of 0.5A when using with a 18650 going for the long haul, but it shouldn't peak at more then 0.8A with fresh battery's to prevent burning out.
What would be a nice value resistor to choose?
Thanx, Vincent
Thanx, Vincent
