Reverse polarity protection
videoman
I am using a DX driver (26110) that is not polarity protected from the input DC source. I would like to have a way to protect the circuitry so that in the event that the input is reversed, the driver would not go up in smoke. Can a simple diode or rectifier be placed in line with the driver in + lead so that the current will only flow in the proper direction ? If so, are there any values of the diode that I should get? The input DV voltage to the driver is between 7.2 to 16V DC. It is a 1200 ma driver ( Buck type)
Try a 1n5820, 1n5821 or 1n5822. 3A Schottky. Or a 1n5401 silicone diode. Also 3A but will have a higher voltage drop. Or 02. Or 03. Whatever you can find I suppose.
Are you limited on space?
Just in case anyone reads the article linked to by qwertyydude a bit too quickly, I'd emphasise that for reverse polarity protection, the FET is connected the 'wrong' way round, so if using an N-channel FET for low-side connection, the gate goes to input/circuit positive, the drain to input negative, and the source to circuit negative.
You might also look for a very thin nylon washer at a good hardware store. I found one that has a center hole just the size of the positive nose of a battery. At 1/16" thin it prevents the negative end of a battery from making contact. I use one for my Nitecore EX10.
That's pretty ingenious. I'd never thought of that.
Yah, that is a pretty good tip. Long ago I bought the "Tonch" from DX (anyone remember that?) it had a similar setup.
Dunno what videomans application is though. At first I thought automotive, but perhaps being videoman it is an external camera light with a separate battery pack. Or who knows.
Thanks for all the responses. I need the protection for a video light. I just want to be sure that if I lend the light to fellow videographers that they will not damage the driver if their battery set up is in the reverse polarity.The light has a DC in plug that has the center tip as positive. There are no standards as to the polarity of 5.5 X 2.1 mm round DC power in plugs as some portable radios and DC powered gadgets seem to have the sleeve as positive and the center pin as negative. A wedding is no time for video lights to fail due to reverse polarity mishaps.
