Hi guys ...
with this review we will see the Armytek Dobermann Pro: tactical flashlight with a latest generation XHP35 HI LED
Armytek Dobermann Pro: Package and content
The Dobermann Pro comes in the classic Armytek cardboard package. On all four sides the main product informations are shown. The package contains:
• The "Armytek Dobermann Pro" flashlight
• Wrist strap
• Nylon holster
• Belt clip
• Cigar Grip in rubber
• 2 x spare O-rings
• Replacement rubber for the switch
• The user manual
Main Features
• Amazing brightness 1700 LED lumens and focused narrow light at the distance up to 390 meters for precise aiming.
• Compact and light-weight flashlight with good price for comfortable mounting on weapon.
• The highest standard of durability — stands up the recoil of 12 gauge shotgun, no-break operation after falling from the height and
even at the 50 m depth.
• Perfectly selected brightness modes and easy operation for comfortable use.
• Marvelous light characteristics at available price for those who need a simple and reliable underbarrel flashlight.
• Compatibility with the accessories for hunting — remote switches and mounts.
• Record runtimes: 1.5 hour at maximal mode and up to 200 days at minimal mode
Specifications (Cool White - Warm White)
• Led light output: 1700lm CW - 1580lm WW
• OTF light output: 1400lm CW - 1300lm WW
• Throw: 395 mt CW - 383 mt WW
• Peak beam intensity: 39000 cd CW - 36250 cd WW
• Body Material: Aircraft-grade aluminium
• Body Anti-Abrasive Finish: Premium type III hard anodizing 400HV
• Spot: 5°
• Spill: 40°
• Batteries: 18650, 2x CR123A, 2x RCR123 / 16340, 2 × 18350
• LED: Cree XHP35 HD
• Waterproof: IP68, 50 mt, 5 ore
• Impact Resistance: 30 mt
• Bezel: Stainless steel con rivestimento ultraresistente al titanio
• Memory Mode: Si
• Momentary On: Si
• Temp: -25 +40 °C
Dimension and Weight
• Lenght: 140 mm
• Body Diameter: 25,4 mm
• Head Diameter: 34 mm
• Weight: 200g without battery or 249g with battery
Output Level, Runtime ed User Interface
Turbo 2: 1300lm (measured 1258) - 1 h
Turbo 1: 745lm (measured 750) - 1.7 h
Main 3: 325lm (measured 320) - 4 h
Main 2: 140lm (measured 140) - 10.5 h
Main 1: 27lm (measured 25) - 50 h
Firefly 2: 1.5lm - 40 d
Firefly 1: 0.13lm - 200 d
Strobo 2: 1300lm - 2 h
Strobo 1: 140lm – 22 h
The user interface is easy to remember. For the variation of the levels, the Dobermann Pro uses the partial rotation (1/8 of a turn) of the head and the double-tailed key for "Momentary On" and "Constant Light".
Basically there are two modes of use that can be selected at will: Tactical Mode and Hunting Mode. The differences are listed below.
Tactical Mode
In this mode, when the head of the torch is completely screwed, with a partial click on the button in the queue you will have the "Momentary On" on the Turbo level, then when the button is released the torch will turn off.
If, on the other hand, the button is pressed fully until you hear the "click", the torch will enter "Constant Light" on the Turbo level. With a further total pressure until the click the torch will turn off.
When we are in "Constant Mode" it is possible to switch from the Turbo level to the Main2 level and vice versa. It is enough (with the torch on) to unscrew and screw the head back quickly to cycle the two levels.
To enter the Strobo special mode, it will be enough to slightly unscrew the head (1/8 of a turn), after less than a second the Turbo will be activated.
With the head unscrewed, with a partial click of the button we will have the "Momentary On" on the Strobe. With total pressure, however, the Strobe will be kept active. When the torch is on, it is possible to cycle on the Strobo2 and Strobo1 levels simply by quickly screwing and rewinding the head.
With a total pressure on the ignition button the torch will turn off and memorize the last level used
Hunting Mode
In this mode, when the head of the torch is completely screwed, with a partial click on the button in the queue you will have the "Momentary On" on the Turbo level as long as the button remains partially pressed. If, on the other hand, the button is pressed fully until you hear the "click", the torch will enter "Constant Light" on the Turbo level. With a further total pressure the torch will turn off.
If the torch head is unscrewed (1/8 of a turn) it is possible to cycle the Firefly1-Firefly2-Main1-Main2-Main3 "Additional Modes". To switch from one level to another, simply turn the torch off and on again (with full or partial pressure).
Turbo Level
There are two programmable Turbo modes: Turbo2 (1300lm) and Turbo1 (800lm). If for example the Turbo is programmed on the Turbo2 level, the Turbo1 level will be disabled and it will not be possible to use it.
To program the Turbo level, a procedure must be carried out which foresees (with the torch off) the partial pressure of the button in the queue for 15 consecutive times. At the end of this procedure, when the torch is switched on, it will emit 1 or 2 flashes, indicating whether the Turbo1 or Turbo2 mode has been selected respectively.
Body and materials:
The Armytek Dobermann Pro is a linear tactical flashlight with an aggressive design and purely shooting features.
The tested version is equipped with the small and powerful latest-generation XHP35 HI (in the Warm White version) capable of delivering 1700 LED lumens (1400lm OTF) to the Turbo. The color is very warm and with an excellent color rendering. On the armytek website the version with Cool color is also available.
Build quality, is excellent, thicknesses are abundant, weight is generous.
The head has a maximum diameter of about 34mm. Inside we find a deep mirror polished reflector and the XHP35 HI led well centered.
The bezel is very protruding (about 1cm), laced, protects the lens very efficiently. The latter has the classic anti-reflective treatment.
The Bezel is made of steel with an ultra-resistant titanium coating.
The Dobermann is a real shooting torch with a beam whose spot exit angle does not exceed 5 °.
The central body is about 7cm long considering also the threads. Here we find already mounted the Cigar Grip in rubber, very convenient to use and easy to extract. It allows you to hold the flashlight in cigarette-style hand or firmly grasped in the palm of your hand
On the body there is a groove where it is possible to hook the belt clip. The clip offers an exceptional grip on the torch and an excellent grip on clothing even though it is very small.
The threads arrive well lubricated with Nyogel. A double O-ring ensures the total waterproofing of the torch. They are anodized and allow the physical lock-out of the interface with the classic ¼ of a turn.
The tailcap has a square profile with rounded corners. Here is the double-stroke ignition button for managing the interface. It is made of rubber, very reactive and at the total pressure emits a loud and ringing "click". Pressed only partially it does not emit any noise. A small hole allows the fixing of the laynard.
The anodization is opaque, well made and uniform over the whole body of the torch. The special finish that Armytek adopts on its torches makes it possible to have an excellent grip while not possessing any type of knurling.
The lettering is abundant, well done and well centered
At the negative pole there is a robust and resistant spring, while at the positive pole there is a smaller and very rigid spring.
The Dobermann cannot be used in tailstanding.
The Dobermann has an antirolling profile that prevents the torch from rolling on inclined surfaces
The Dobermann Pro can be powered by different types of 18650 batteries both flat top and button top. Alternatively, the 2xCR123A, 2xRCR123 / 16340 and 2 × 18350 power supply configurations can be used. The accepted input voltage, in fact, varies from 2.7V to 13V.
Armytek recommends the use of high-drain cells (at least 7A of discharge).
Along with the torch comes a comfortable Nylon holster, a wrist strap, a spare tire for the switch, two O-rings and a belt clip
Beam, Tint and Beamshot
Il fascio della Dobermann è pulito ed uniforme, molto stretto e con uno spill concentrato. È possibile illuminare "a giorno" ad una distanza di 180-200mt. La tinta è uniforme, molto gradevole, calda e rende davvero bene i colori. La geometria del fascio non presenta alcun tipo di artefatto.
I livelli "Firefly" sono comodissimi per utilizzare la torcia per le distanze ravvicinate e senza disturbare la vista quando ci si trova in totale oscurità.
A seguire qualche scatto al Turbo 1 e Turbo 2. Alcune foto sono state fatte in presenza di una fitta coltre di nebbia che mi ha "perseguitato" durante tutte le serate dei test XD. Questo però permette di capire bene come realmente sia la geometria del fascio.
Beamshot 1
Beamshot 2
Beamshot 3
Beamshot 4
Final Considerations
The Dobermann Pro is a beautiful tactical shooting torch, with many well-spaced levels and two convenient modes of use to be exploited for multiple use cases.
The materials are of quality, abundant thicknesses and everything is taken care of in the smallest details.
The switching system is beautiful thanks to the rotation of the 1/8 head and the power button which allows both the "Momentary On" and the "Constant Light" is very practical.
We have a real firefly level of only 0.13lm with an exceptional theoretical duration of 200 days and a 1300lm Turbo. The beam is uniform, well focused and with an excellent shot. There are also two programmable Turbo levels.
The color is warm, of a nice yellowish Warm and that gives good colors especially in nature.
Temperature control works effectively and protects the torch from overheating
The Armytek Dobermann is a Flashlight to recommend!!
• Wrist strap
• Nylon holster
• Belt clip
• 2 x spare O-rings
• The user manual
Main Features
• Spot: 5°
• Spill: 40°
• Memory Mode: Si
• Momentary On: Si
• Temp: -25 +40 °C
• Lenght: 140 mm
Tactical Mode
Hunting Mode
Turbo Level
Body and materials:
Beamshot 1
Beamshot 2
Beamshot 3
Beamshot 4
