randomlugia
- Joined
- Feb 12, 2009
- Messages
- 146
Packaging/First Impressions
The light came in a simple white cardboard box, that was put inside of the bubble-wrapped yellow packaging typical of DX. I'm going to say right away, this is the highest quality DX light I have ever owned, both as a first impression and thinking about it now. LINK
Compared to the Spiderfire P7 and 4D Maglite:
The light is thinner, longer, and heavier. The knurling is deep; so I can get a very good grip on it. The Spiderfire P7 had one thing that bothered me, and that was the smaller middle section. It was only long enough to grip with a few fingers, otherwise the raised ends would make it feel awkward. The Aurora has a tailcap with the exact same diameter as the middle, so you can grip the whole light from right behind the head perfectly. That, combined with the deep knurling, makes it really comfortable to hold. I'm giving it a 10/10 for design!
The textured reflector seems to be good (beamshots below), o-rings are thick and very waterproof, it uses my favorite clicky (a gold button on the inside, instead of a spring that drills holes in your battery), the LED is centered, and the threads are perfect and smooth after some lubing. The printing on both sides is also sharp.
Performance
I would call this a mid-range light. It throws better than any other P7 light I have, but P7's are never made for throw. It's not designed to be a flood light either, but the sheer amount of brightness gives it a great spill as well. What I really love about this light is the warmer tint. Not so warm that it appears yellow, but just enough tint to make it pleasing to look at and give it a higher CRI.
I measured this on the DMM, and the LED is pulling a little over 3 amps. Perfect! The light gets very warm after a few minutes on high, but nothing serious. I would not, however, recommend keeping this on high for ~40 minutes. Both for the sake of the light and the skin on your hands.
BEAMSHOT TIME!!
Spiderfire left, Aurora right:
Stepped down:
Ceiling bounce test for overall output. Maglite:
Spiderfire:
Aurora:
See a difference? The Spiderfire clearly isn't being driven near 3A, more like <2A, as are most the the DX P7's. The AK-P7-5 2-mode is apparently the most consistently correctly driven light on DX. Moving onto the great outdoors:
Location #1: Flood
These will be in order of apparent brightness.
Maglite focused for throw, then flood:
Spiderfire, low:
Aurora, low:
Spiderfire, high:
Aurora, high:
Location #2: throw
Sorry about the bush, and the blurriness on this one; it's hard to focus a camera on something that far away in pitch-black darkness.
Maglite, Flood then throw:
Spiderfire, low:
Aurora, low:
Spider, high:
Aurora, high:
Location #3: midrange
Where P7's excel
Control shot:
Sorry, no more controls. I forgot to take them while it was still day, lol. They might be up later.
Maglite, flood then throw:
Spiderfire, low:
Aurora, low:
Spiderfire, high:
Aurora, high:
Conclusion
Here's a quick summary:
Pros:
-Bright, and consistently bright
-Feels solid
-LED is centered
-Sharp printing
-I don't like flat heads, and the bezel on this one lets you know if the light is on when it's facing down
-Threads perfect after lube
-Really nice transition from hotspot to spill; no rings
-I love the general design and grip
-Protruding clicky switch
-Deep knurling
-Dunk/splash proof
-Not a single flaw in the finish upon arrival
Cons:
-LED pill won't unscrew
-The smallest bit of a donut in the beam, but you can only see it indoors well.
-Some people prefer forward clicky, others like reverse. This is reverse.
-Gets hot. This is good, because it means good thermal contact, but bad, because too much heat is obviously not good for the P7.
-There is a lot of empty space around the reflector, which could have been used for more heatsinking. But then it might get too top heavy, so I'm not sure about this.
-It can't tailstand, but the easier to access switch more than makes up for it.
-No lanyard hole
Final thoughts:
This light is amazing for the price, I would have paid a lot more for it than I did. If you've been trying to decide on a cheap P7, stop looking and buy this one now! Make sure you get the 2-mode though, because the 5-mode doesn't drive the LED nearly as well.
Performance
Stepped down:
Spiderfire:
Aurora:
Location #1: Flood
Spiderfire, low:
Aurora, low:
Spiderfire, high:
Aurora, high:
Location #2: throw
Spiderfire, low:
Aurora, low:
Spider, high:
Aurora, high:
Where P7's excel
Control shot:
Spiderfire, low:
Aurora, low:
Spiderfire, high:
Aurora, high:
Conclusion
Pros:
-Feels solid
-LED is centered
-Sharp printing
-Deep knurling
-Dunk/splash proof
Cons:
-No lanyard hole
Final thoughts:
