Hi All! Olight sent me the I1R to test and I wanted to share my thoughts with you here.
The I1R is a USB-rechargeable key chain light from Olight which boasts 130 lumens and at a super affordable price point of around $19 USD, you should pick one up and try it on for size.
Link to manufacture product page: https://www.olightstore.com/olight-i1r-eos
OVERVIEW
Overall, I'm impressed with the beam pattern (thanks to the TIR lens) and the fine knurling all over the body. Some things to consider is that the head has to come all the way off to recharge, so don't loose it.
QUICK SPECS
Copied from Olight Store product page.
INCLUDED
OPTIONS
Only one option currently.
PRICE
Current price is about $19 USD
LOOK & FEEL
OUTSIDE
The knurling is very fine but covers a large are which helps with grip. The size overall is pretty small but usable. The light uses a TIR optical lens for a smooth beam profile. The light comes with a single small key ring.
INSIDE
The light is easy to open and there is a number of threads so it's not likely it will come off by itself. I get a little anxious when I have to have exposed my threads to the world during charging as I don't want them to get dirty and bind when I'm putting it back together.
ACCESSORIES
This beautiful, but short, micro-USB cable also comes with the light.
OPTICS
LED SPECS
The light uses a Philips LUXEON TX which I've never heard of before.
BEAM PROFILE
Olight does not advertise the angle of main LED but from what I've collected it seems to be a 100 total degrees spill with a 40 total degree spot.
The first rectangular graph is cut across the beam and helps a bit better to see what angle the spill starts at as usually it is quite a bit dimmer then the center. It's quite possible that a very low lumen outer spill might not register using these methods. The percentage is a relative comparison to the brightest light recorded (generally, in the center).
The second, polar graph, is a simulation of the light along the beam.
Currently, these readings are strictly sensor recorded, and are not adjusted based on human perception of light but may be an interesting idea for the future.
TINT
The i1R (left) is a bit cooler and a little yellow compared to the Nichia 219B (right) (in the Nitecore MT06MD)
OUTPUT LEVELS
Low and High
POWER
BATTERY
The light has a built in rechargeable 80mAh 3.7V Li-ion Battery. I tested and confirmed the capacity by observing the charging current over time, as shown below.
CHARGING
The light took about 1h 17m to fully charge. Summing the current over time, I calculated at cell capacity of about 82 mAh.
INDICATORS
While charging, the indicator light will be steady red, when complete will be steady green. To be considerate to color blind people, Olight may want to consider adopting a blinking red and a steady green scheme.
PERFORMANCE
NOTES ON METHODS
I measured the light output in relative LUX and I have not spent time yet to calibrated for lumens or factored % of max output. The charts I've provided, while are literally quantitative, I suggest using as a qualitative reference for how the output may behave over time; typically lights aren't left on this long and the max output can be reset.
PWM check using a 50 millisecond test period with a sampling rate of 3,000 times per second.
Temperature measurement condition is at room temp and currently no fan cooling.
I am still very new at doing these types of measurements so I am no authority on on this subject, but please let me know if things don't look right or you see anything that I could do to improve for next time.
RUNTIMES
Pretty much as advertised, the light runs on High for 20 min. Soon after, I did a manual reset (turn the light off then on again) but the reset did not return the output to 100% output.
TEMPERATURE
A very mild max body temp of 84°F and max 'out-the-front' temp of 93°F was observed for HIGH.
PWM CHECK
There appears to be no significant PWM on any constant mode. For comparison, the second graph shows PWM varying from 0 to 120 lx on the LOW mode on the Nitecore R25 flashlight.
USER INTERFACE
Very simple 2-stage twist interface. As you tighten the head, the light will turn on into LOW and as you continue to tighten, the light will jump up to HIGH. Loosen the head to reverse back to LOW; continue to loosen to OFF.
CONCLUSIONS
HIGHLIGHTS
COMMENTS
NOTES
Disclaimers:
OVERVIEW
QUICK SPECS
Beam Distance (ft) | 177 |
Beam Distance (m) | 54 |
Max. Performance (lumens) | 130 |
Charge type | Micro-USB |
Compatible Batteries | Customised Li-ion Battery |
Light Intensity (candela) | 730 |
Light Form | Wide/broad hotspot. Perfect for up close illumination. |
Lens / Reflector Type | TIR reflector (big, defined wide hotspot) |
Mode Operation | No Switch |
Form/Size Factor | Small size (Car key / Zippo Lighter) |
Series | Series I (Keychain) |
Unique Characteristics |
LIGHTING LEVELS | |
LEVEL 1 (lumens) | 130 |
Run-time LEVEL 1 |
LEVEL 2 (lumens) | 5 |
Run-time LEVEL 2 |
Strobe | No |
SOS / BEACON | No |
TECHNICAL CHARACTERISTICS | |
Waterproof | IPX8 |
Weight (g / oz) | 12 / 0.42 |
Length (mm / in) | 41 / 1.61 |
Head Diameter (mm / in) | 14 / 0.55 |
Body Diameter (mm / in) | 14 / 0.55 |
Led | Philips LUXEON TX |
INCLUDED
- i1R keychain light
- Decorative micro USB cable
- Manual
OPTIONS
PRICE
LOOK & FEEL
OUTSIDE
INSIDE
ACCESSORIES
OPTICS
LED SPECS
BEAM PROFILE
TINT
OUTPUT LEVELS
Low and High
POWER
BATTERY
CHARGING
INDICATORS
PERFORMANCE
NOTES ON METHODS
RUNTIMES
TEMPERATURE
PWM CHECK
USER INTERFACE
CONCLUSIONS
HIGHLIGHTS
- Small and bright
- TIR optic lens
- USB Charging
- Fine but tactile knurling
- Traditional twist interface with an upgrade
- No PWM
COMMENTS
- Have to completely remove head to charge (exposes thread and chance of loosing head)
- A little bigger battery would be nice, I wouldn't mind it having to be a little longer
NOTES
Disclaimers:
- CivilGear Reviews received this product for testing and providing an honest review.
- CivilGear Reviews was not paid for writing this review.
