Well, I got my FM Deep M*g reflector and dropped it in...the first thing I noticed was the beautiful polished SMO reflector was pristine, and fit my Mag like a glove. It dropped right in, and the stock bezel screwed right on.
That ugly batwing beam pattern...gone forever!! Even with the SMO reflector, it totally turned that crazy shaped hot-spot into a perfectly round circle. The beam pattern it gave my Mag85 reminded me of my Deree DBS - very defined, perfectly cutout hotspot and bright sidespill.
Then I took it outside - I must say my initial impressions were that it threw way better than it did with the stock-sized, Litho LOP reflector. It just had that laser beam look to it, and it lit up a treeline way in the distance.
So I set up my camera, and did a quick shootout between my new FM Deep reflector and my Litho LOP reflector. I used manual settings, with a 3 second exposure, daylight white balance, ISO 200 on a Fuji F30
Here we go:
Ver2 Deep M*g Reflector by Fivemega
Fivemega Deep Reflector installed
Litho LOP Reflector Installed
Target - Tree at 175 Yards (525 Feet)
Ver2 Deep M*g Reflector by Fivemega installed
Same images cropped close in to the target:
Here are animated Gifs for better comparison
(Unfortunately I couldn't add text in this version. But it's pretty obvious the more narrow beam is the FM reflector)
Uncropped:
Cropped
Here is a super-close crop of the hot spot:
FM Deep M*G.............Litho LOP............... Animated Gif
My impressions: This is another quality item from Fivemega, as always. I must say that I was surprised when I was doing the beamshots, that after putting the Litho reflector back on and going outside, I was expecting to see a lot less throw from the Litho reflector in comparison. I was surprised that it seemed to light the target up as well as the FM Deep reflector. Prior to doing a direct comparison, the throwy nature of the FM deep reflector made it seem like it had much more reach than the stock-sized reflector. It is clear in the beamshots that the FM reflector does take some of the spill on the outskirts of the stock-sized reflector and bring it in closer, but it looks like it is putting the extra lumens back into the spill beam closer to the center of the beam, but not to the hotspot. But these are only my observations from this shootout - your experience may be different.
If you are looking for a solution to clean up your Mag85 beam profile and give you a nice round hotspot - then this does that beautifully. It provides a very nice beam pattern while allowing you to use a SMO reflector. If you are only wanting to get more throw out of your Mag85 than you're getting with your stock-sized reflector, my beamshot comparison doesn't conclusively show that this will provide a large gain in that area.
UPDATE: Mudman CJ posted that he saw a substantial improvement in throw on his Mag11, that was measured on a light meter to be 16,000 Lux greater with the FM Deep reflector than with the stock-sized SMO. This is a 53% increase in throw!! This may be due in part to the smaller filiment of the WA1111 vs. the Mag85. Also - as I don't have a light meter there may also be some level improvement in the Mag85 Lux that just isn't easily discernable with my eye or camera, so bear this in mind. Now I know there are a lot of Mag85 owners out there that bought an FM Deep reflector - do any of you have a light meter that can test this??
-Rich
Here we go:
Uncropped:
Cropped
-Rich
