Re: Civictor V1 Special Edition Interest Thread...
I'm in. I've already actually stated I want something like this on the LOPSE threads.
I like twisties better than buttons for the sole reason of accidental battery discharge and emergency use.
To me its semantical about which actual brand of LED they use. My main goal is to get a 1-AA twisty with 3 brightness levels, and just like everyone else here said, LOW should be LOW.
Do I need a brighter than 30 or so lumens light in a 1-AA package? I think given the form factor, you are compromising too much usability with respect to run-time on HIGH. If you can't get at least an hour to 50% on HIGH, then it becomes a specialty light, not a common use light. For that, there are different form-factors you should be using.
Of course if Cree LEDs can provide 60 lumens and run to 50% after an hour, and they can do 4 lumens for 10 hours, I'm all for it. But I care more about constant brightness for specific times at multi-levels given the form factor than I care about anything else.
Fenix DID do the right thing with the LOPSE by making the light cycle medium -> low -> high. Should it be low -> medium -> high? I think you can make a case for both given the form factor, but certainly not high as the default.
I would suggest that you have a compeletely different objective with a multi-stage light vs. a single stage, and more thought should be put into those outputs based on the amount of stages being offered.
Low should be just low enough to navigate around in complete or relatively so darkness without worrying about stepping on something or IN something. Low isn't about being able to see exact details, just that something is actually there! This is especially true when you already have medium and high levels to switch to if you need it.
Honestly, with respect to the LOPSE, I would have rather seen an E0 sized light that has two stages given the AAA form factor. I think a 2 - 3 lumen low and a 10 - 12 lumen high would have been a very nice compromise. Then you let the Civictor AA form factor handle the lux like lights at 3 levels.
Of course, my eye is towards practicality and run-time efficiency with respect to the lights that I own. Something that burns as hot as the sun for 10 minutes that's the size of a quarter still wouldn't cut it for some of the people on this forum. I'm just not in that group.
