Curious_character
- Joined
- Nov 10, 2006
- Messages
- 1,211
Here are runtime graphs of a Ray-O-Vac "3 watt" flashlight (identical to a Nuwai X-3 I got earlier). One graph is the original light and the other after replacing the emitter with a Seoul P4. The estimated total output of the original is 49 lumens, and the modified light 97 lumens using a Quickbeam type measurement box. As you can see from the graphs, the ratio of lux measurements isn't as large as the 2:1 lumen increase, showing that the beam isn't as tightly focused after the LED replacement.
This is my first attempt at posting a run time graph from data recorded by a new meter. The meter is a NIST-certified ExTech 401036, so the readings should be about as accurate as a hobbyist can get. They are, of course, representative of only a single light, and others of the same type might be significantly different. Comments and suggestions about the graph format are welcome. If they're useful, I'll try to post others from time to time.
c_c
c_c
