Re: Interest List: Exolion in Stainless Steel
Not sure if this is possible but I must ask.
Can this SS unit differ from the Ti by having a new menu. For example, low, high, burst, strobe, SOS, Adjustable low and high setting. I find the extra low, high, burst to be useless. If I miss the setting I want I wait 0.8 seconds and start over. I think these need to be replaced with more useful settings. I would strongly recommend making low and high adjustable. Because the low on the Ti is too bright at night (for me). I have made the high setting lower than low but I still have to click past the "bright low" to get to it. Plus making both adjustable would make it more appealing to the people who want the bright setting to come first.
I know this is possible (already exists in FF3) just let me know if you are willing and then I would be in for one of the SS units. The Ti unit is awesome. I would welcome all comments surrounding this. I know it would be a piece of cake for goldserve to do.
Oh one more thing I found with the Ti. The foam on the bottom caused problems for my RCR2 batteries that I all ready had (they were a lot taller and had a plastic lip on the bottom). To fix this I ripped out the foam ring on the bottom and put mole foam on top and all my batteries work perfect. Plus it is a lot easier to turn now. However, the original battery will not work without some Al foil on the bottom to raise it. But all my regular CR2s work. These CR2 batteries worked in my CR2 ions without spacers. And I think the length has increased a bit for the CR2 batteries because I saw a AW post that the new (newer?) batteries work in the CR2 Ion now without the spacer. All I am trying to say is you may want to include the foam ring on the board side or no foam at all. I have done the mole foam on my Fenix P1, Jil DD and now the Exolion Ti and they all work fine with no battery rattle. I would recommend no foam because I believe that would be less headache for you.
Thanks for reading.
rob
Edited update:
I am not sure if the smaller size CR2 that came with the light will work or not work because I think the battery appears to be dead. When I made the comment above I assumed it to be the size but then I tried adding spacers and none worked in the light. I can not even get the light to change in my Nano or DSD charger to respond when I put the battery in. It's like there is no battery there for both chargers. So I can not comment on the shorter batteries since I now own none. - Thanks rob
