Billson
I have 10 Sanyo 2700 cells all bought in the last six months and I decided to cycle them last week after some intermittent use over the past few weeks.
I have always used the BC900 with a fan blowing over the cells because of the meltdown experienced by some of our members. For the tests to be consistent, I fully discharge the cells first then do the test cycle using 1000ma charge and 500ma discharge.
The cells have less then 20 cycles on them including the first 5 cycles of break in so they have no more than 10-15 cycles, probably less, in real world use. I am very careful with these cells so they have never been abused or dropped.
I noticed that out of 9 cells(1 not available for testing), 4 of them had dropped in capacity. After noticing the drop in capacity, I decided to repeat the test cycle to verify this and they came up the same.
Cell 1 from 2.75Ah to 2.56Ah
Cell 2 from 2.80Ah to 2.72Ah
Cell 3 from 2.72Ah to 2.65Ah
Cell 4 from 2.72Ah to 2.60Ah
I still haven't noticed an increase in discharge rate but I won't be able to verify this after a few more days but the voltage across all the cells seem to be consistent after a few days of rest.
All the slots are consistent when I cycled the same cell through all 4 slots. The readings came off more or less the same.
I'm a bit puzzled about this and I'm wondering if the BC900 may be hard on the cells or if this is normal for ni-mh because I don't think they will last 500 cycles if the pattern stays consistent.
