There are some AA -> D adapters available that let you configure 1 - 4 AA cells. I was going to order some, but the shipping cost was insane for me
EDIT: Here they are:
http://www.aventrade.com/baad.html
Slight thread hijack, but most brands* of NiMH AA cells will not fit 4 astride inside a D-side M@G light, even without an adapter present - The inside diameter of the flashlight body is simply too small to accommodate 4 of them sitting next to each other. You might be able to omit one AA cell in Aventrade's 4-cell adapter (i.e., just use 3 cells), but then that leaves some space on one side of the adapter for it to shift off-center (and possibly lose electrical contact).
*A few random brands of AA cells I checked:
Kodak NiMH 2100 mAH Pre-Charged: Won't fit
Lacrosse NiMH 2400 mAH: Won't fit
Sanyo NiMH 2500 mAH: Won't fit
NEXcell NiMH 2100 mAH: Won't fit
Digital NiMH 2200 mAH: Won't fit
Kodak NiMH 2500 mAH: Won't fit
Duracell NiMH 2650 mAH: Won't fit
Targus NiMH 2500 mAH: Won't fit
Energizer AA Lithium: Will fit
Panasonic NiMH 1600 mAH: Will fit
BOTTOM LINE: Be sure to test-fit 4 of your intended AA cells in your intended flashlight before ordering these adapters.
