Just for fun, i made a light using only household items. It looks quite good though. I even use this one in the house.
The Donor led unit was from a cheap 16 LED headlight. (~20-25lumens i guess) I used plastic tubes, caps and other scraps i found in my drawer to build this.
The switch is a reverse clicky from a cheap 3 LED flashlight. (2 of its 3 led died, so i disassembled it for my scraplite project) The battery carrier is also from this cheap flashlight. It Uses 3 AAA batteries.
The blue body is from a wet mop handle. (Thick plastic tube)
The head is a plastic deodorant cap.
The tailcap is a plastic copier toner cap. (this one is in my drawer for 6 years. i knew it will be good for something)
The custom made button extender is a small cap of a pen tube + rubber ring + something white plastic ring.
The positive contact is a 4-5cm long screw in the head.
The negative contact is a wire inside the body.
There are some metal rings inside the head, and some things (like spacers, plastic tubes) that are unnecessary to mention here.
The upgrade options are limited here, since it is pure plastic. I surely don't want a melting light in my hand. :D But i consider to get a 37led headlight or something that fits there.
more images:
mirror: http://img825.imageshack.us/img825/5240/scraplight2.jpg
more images:
