several convoy S2+ osram questions,
mickb
Australia
Folks I was informed this 'Osram' is probably the longest throw in the Convoy S2 line
https://www.aliexpress.com/item/1005001543265036.html
One feedback buyer comment I saw estimated 25KCD for this little light, which is the ballpark I am after.
Was wondering if anyone could indicate the link to the remote pressure switch that would suit it?
Also wondered what the main differences are between the S2 and S2+ designations? Had read the S2 has a deeper reflector, so would there be versions of the S2 that throw even better?
Any guesses as to whether this unit will fit protected button top 18650's?
Thanks in advance!
I believe that S2+ is an updated version of the S2.
Its a budget line of flashlights. The only light that I have seen that has a pressure switch, IIRC is the C8+ line of lights.
The S2 does indeed have a deeper reflector than the S2+, but that only matters for spill angle. Hotspot should be the same on both, so it is up to preference.
Otherwise the differences are that the S2 is a hair longer (matter of 2mm or so), has a thinner pill, and the tail button is completely encircled by a raised ring with no thumb cutouts. Aside from these, the differences are purely aesthetic.
EDIT: D'oh, missed the main point of the thread! :fail: Sorry, no pressure switches for it unless there's someone I never heard of that makes aftermarket ones.
