I'd like to see a knockoff light like this. I just received a Uniquefire L2 XP-G with is a 6P clone.
All it would take to make something like this truly dive worthy would be a ledge in the head to support an o-ring that would compress with depth and a solid tail cap.
I've converted similar lights and tested them to 100fsw but I like this light and don't want to screw it up.
Converted to a solid tail cap is easy...just take the switch out and epoxy over the hole. Without a proper support for a front lens o-ring the only solution I've found is just to use silicone sealer behind the glass lens. It works but it's a bit messy looking. I'd prefer to have a proper compressing o-ring there.
Are there any 6p clones out there with solid tail caps and compressing o-rings in the lens area? If anyone finds any, whether it's rated for diving or not, I'd like to know about it.
