BIGLOU
- Joined
- Jan 14, 2009
- Messages
- 717
Hello CFRers. I bummed out, I discovered my SF CN411 A/C plug T120 (8AX) is not working. I know its not the actual charger or the battery because the D/C plug works fine. The red light wont go on basically. I was wondering if anybody has had this problem. I did leave the A/C plug part connected for while into outlet, did notice it did keep it warm. Do you guys think SF will warranty it? Do you guys think it will be safe to use my Dominator 10X A/C plug? Is this LEGO too? Noticed it was the same T120 on SF web site photo but it doest look same as mine, 10X has a two piece plug with the rectangular box looking thing. I accidentally swithed it before it did charge but decided not to mess with it and use correct plug, was not sure of amp. and volts. If anything maybe I just drive to FV to drop off. Thanks Guys.
