Solscud007
Ok so i just got a E1L and E2E.
The E1L came with a KL1. I put it on the E2E and it works. It seems it is the same brightness as the E1L.
Now if I get a KX1 what will happen if I use it on my E2E? Or do I HAVE to get a KX2?
Also how does the KX dual output work? How to you switch from HO to LO? or is the dual output like the P60L lamp, where it dims after a while from tactical to general usage brightness?
Where can I get a C-E adapter to use C/P heads on an E-series head?
Can some one suggest what other options I have? I want to make my E1L as bright as possible. I know of upgrades for SF that use P60 lamps. but know nothing about the Executive series.
Thanks
Thanks
