SF LED upgrade for G2Z/Z2?
N467RX
Is there a LED upgrade for the G2Z or Z2 that brings it to over 100 lumens? Right now I have a non-LED 9P, but I'll be moving for college in summer, and it's very likely that I'll get a new SF and leave the 9P here. If that is the case, I want to see if I can get a smaller one like the G2Z or Z2 that will give me more than 100 lumens with a LED (the xenon lamp upgrade is not an option because I don't want to be carrying a box full of batteries every time I plan to use it).
Malkoff M60L would work well with what you have. FWIW my 0.02
Good luck finding one in stock. :shakehead
I agree, though, he makes great drop-ins, you should go for that if he has one available.
It's only 20 more lumens, though, plus I'm not sure on warrenties, it might void your Surefire's, and it's a bit ringy.
If you try, it's not all that hard. I have (3) M60's, (3) M60L's and (5) M60LL's. I got them at 3 different times, just have to be ready when they come out! I think they are WELL WORTH the wait! FWIW my 0.02
The issue with the P61 lamp is that it brings the battery life down to 20 minutes, that's why I wanted a LED upgrade. I don't mind the 1hr battery life of the 3x 123 ones, but 20 minutes is nothing.
And what's the change required to install the M60L on a Z2/Z2LED?
They don't call it a drop-in for nothing!
No, but I don't know how the factory LED flashlights are like, so I don't know if you just change the actual diode or you need to change some other part (like a reflector or someting of that sort.
You know the lamp+reflector that you can change out? the drop-in will just replace the whole thing. Malkoffs IMHO are some of the best in the business...
http://www.dealextreme.com/details.dx/sku.11836
those are good to, although depending on when you leave for college, you may or may not get them in time.
using them or any other drop-in will not void surefire's warrenty as far as i know.
Crenshaw
I have Deereelight Q5 drop in for my Z2. I like it and is bright. I think it's over 200 lumens.
The build quality of the Malkoff M60 is quite impressive to say the least.
