It's not as huge as one might think cause the NDI is tweaked so well to use primary AA's, but it is noticeable. I don't know about lithium primaries tho, never tried one. I've only used Nimh and 14500s. It's enough of a difference on 14500's that I won't be going back to the eneloops anytime soon. I notice more throw and a brighter spill. Just plain brighter all around. I think it's worth it to run the 14500's even with the initial cost. Others may not think so. :shrug:Seeing as there are owners of the NDI here, ill just ask, how much of a difference is there between 14500s and AA lithiums/alks ?
Crenshaw
Liteme,
I have been thinking about buying some 14500's but I already had some of the Rechargeable Energizer 2500 mAH batteries on hand and they work with the NDI and offer good output. Would using the 14500's offer higher output levels, better run time? Any one know?
Thanks,
Crenshaw,
When does your NDI arrive?
I have only had mine since last Friday and have been playing with it alot over the past few days. I am using a rechargeable Energizer 2500 mAH and I am very pleased with the output - I can't say that I have really run the light for a very long period so I can't speak to the runtime at varying output. I will need to perform some tests to check that out. I think you wil be pleased with the light. Let us know when yours arrive and what you think.
Khaytsus,
at the MP post, they claim 130 torch lumens, in bold, because they wrote it in bold too, but 14500s do seem to have a flatter regulated runtime curve..:shrug:
does that mean edgetac has an intergrating sphere? oo:
Crenshaw
The moderator should have locked this thread ... I was happy with my 120Ps until reading this & a PM from a member ... so in the best CPF tradition, the NDI has joined the stable
If for any reason you don't like it, PM me with your selling price ... I only have two so farat least until my 120P arrives
The NDI is interesting ... I haven't had a AA light since the L1D CE got traded for a Surefire L4 (I hope to live long enough to see that happen again). I plan to use Eneloops in the NDI, which should be interesting.
I have been running Energizer Recharable 2500 mAH batteries int he NDI since last Friday and with frequent use it is still running strong. I ordered some AW 14500 rechargeables based on everyones suggestions and will try those out when they arrive. I keep reading about the Enloops and may have to give them a try at some point also, but how many different batteries can you have for one light!!!??? :nana:
I can relate to that!how many different batteries can you have for one light!!!??? :nana:
The following mnemonic helps me remember the options when setting the dark: "Beacon signal locator for butt(-lock) timers, (a) simple tactical option." I can never remember how to do the "new rechargeable battery reset". That is all the users manual I seem to need. NOTE: by powering on to "maximum" (with click-press) it's brightness can also be set.Just received a BNIB from a fellow board member! Looks great and I'm still reading that big manual too figure out the functions.....This light makes a good companion to my NCDI!
I tried and tried. Then I sat on it while I worked on the computer, tried again and it slowly rotated right off...Now if I can only figure out how to get that insanely tight original bezel off I can install my new mods
I did not notice any signs of loctite but if there is any I don't think it takes much heat to weaken, maybe a hair dryer for a few seconds. Not into the lens though, I don't know how polycarbonate holds up to heat.
I knew that loctite breaks down with heat.Fathom,
What made you decide to sit on the light?? :thinking:
