The internal resistance of the battery is displayed with the unit milliohm. 200mOhm versus 50mOhm would be a bad sign for the battery. This means that this battery is no longer so well suited for lamps with high current requirements.
However, for reasons of principle (high contact resistances), all slot chargers with spring-loaded minus sliding contacts are not well suited for an accurate internal resistance measurement. To keep this fundamental error as small as possible, you could do the following:
When inserting the battery, you should immediately press the negative contact against the battery with one hand and turn the battery back and forth with the other hand. This should at least ensure that the contact resistance at the battery terminals remains as low as possible and that no incorrect value that is too high is displayed.
A further contact resistance between the negative pole sliding contact and the device-internal negative - rail contact connection you can probably little influence.
With several measurements in a row, I use the lowest displayed value.
When measuring internal resistance, the battery should not be empty and should have normal room temperature.
In HKJ's charger test of this charger, he noticed that the displayed internal resistance values were displayed approx. 50% too low. That was then relatively constant, so that a comparison between different batteries is possible.
