pe2er
I Got a Sigma Mirage EVO - just the head, no battery.
The light is intended to be used with a 5 cell NiCd battery (6VDC nominal).
I Have hooked it up to a 2 cell LiIon battery (7.4 VDC nominal), so it is slightly overvolted. I Looked inside, and found a capacitor on the PCB that has a rating of 16VDC max, so no problems there. IC Was not identifiable (just a dark blob on the PCB). It seems to work just fine:
Just the battery indicator LED is off until the voltage gets close to 6V - then it illuminates Green.
Question is: Will it survive prolonged operation at 7.4V Volt (8.4 Volt just after recharging). Any experience?
