Looking at a spare quark AA body tube with clip and end caps I realized I had a very simple DIY project in my hand:
I have an old headlamp with 5mm LEDs where it is really easy to mount a steel clamp that will fit all these arrangements nicely.
I do have a slight twitch by exceeding the 0.9-4.2 volt spec ever so little with fresh batteries, even if it will be just for a few minutes. I still have the option of shorting out one of the 3 battery slots, leaving me with a 2*AA quark headlamp. Which still is a great thing. But the run time of a 3*AA quark headlamp would be AWESOME :)
For further refinement, buy yourself a quark 18650 tube with end caps:
- Drill a hole in each end cap.
- Improvise an electrical connection at each end.
- Toss the 3*AA compartment, hook up the 18650 body tube.
Voila, a quark 18650 headlamp :)
- the clip has a slot in it. Insert two bolts and you can mount it to anything
- or use the clip as is, secure with rubber bands or zip ties.
- It should be fairly easy to make a reliable electrical connection some with unanodized aluminium on the body - you probably don't have to cut anything if you use the clip / clip retaining ring (that is screwed on with unanodized threads. Or you could just drill a hole.
- It should be fairly easy to make a reliable electrical connection for the positive terminal: Use a steel / copper bolt cut to length, wrap lots of electrical tape around it until it fits snugly inside the body tube. Drill a hole in the end cap for the wire.
