PaulW
So simple that you might not even call it a mod. All I did was to take out the stock bulb and replace it with a 3-cell Mag bulb. I know, others have done this before, but I couldn’t stop myself from telling you all about it.
The host. Today I drove over to my local Sears store and picked up a Craftsman 4 AA Tool Light (34-93068). I understand that this is like the Dorcy boss. Length 5.0 “ - Diameter 1.9" - Bezel dia. 2.5”- Effective reflector (faceted) dia 1.75” - Body rubber-coated plastic - Spare bulb in cheapie lanyard - LED battery level indicator - Cost $7.99.
The beam. I like this light. It has an oval, almost circular, well-defined hot spot about the same size as the SureFire A2. The light intensity at 1 meter is 2300 lux when the batteries (alkaline) are new. This is about equal to the Surefire A2 and a little less that the E2e when its batteries are fresh. There are minimal artifacts; a white wall is needed to see them.
Run-time.This configuration overdrives the 3-cell bulb considerably, but the bulb seems to be okay (now on the second set of batteries). Initial intensity is almost twice what is put out with 3 C cells. The following is a run-time test I did. The lux levels are relative -- shown in percent of the level from 3 C-cells.
Minutes_Volts___Amps__Lux (%)
___0.5__5.47___1.05___175
___2____5.27___1.03___156
___5____5.03___1.00___137
__10____4.80___0.97___120
__21____4.51___0.94____99
__30____4.37___0.92____88
__40____4.25___0.91____81
__52____4.11___0.90____73
__62____3.99___0.88____66
__71____3.855__0.87____54
__80____3.69___0.85____48
__91____3.35___0.81____35
__97____1.40___0.29_____5 (ambient light - bulb not lit)
Credits. It was reading this thread that prompted me to go to Sears. In it PlayboyJoeShmoe suggested using the 3-cell Mag bulb in a 4AA light such as this. Illuminated posted a picture of the light there.
