daanderson911
- Joined
- Jun 23, 2009
- Messages
- 6
Good Afternoon,
I have been working on a small project for quite a while, but I am not an electronics, or by ANY means an LED guru. I need some suggestions, but my options are vary limited... So, here goes...
What I need in an L.E.D.
- Superbright white LED that will illuminate a 4ft. section of wall at 10ft.
(General use, similar to a flishlight)
- Measurements as follows: Absolutely no larger than 9.95mm. (Perhaps
10mm LED slightly shaved around the edges? I would prefer something
the size of 5-6mm overall)
- There is no limit to the length, just the diameter.
- At least 6hrs continuous use using batters no larger than 8MM. (Lr41 is
what I am currently using. Can expand from 3 batteries up to 6 total.
(I haven't a clue what the output for an LR41 button cell is)
If ANYONE could give me some ideas, I would be eternally greatful, because as it sits right now, I'm kinda clueless on any sort of LED to use.. Thanks in advance for any possible suggestions...
