WARNING - forgot to mention that these voltages are at a 68F temperature. Fortunately the morningstars are temperature-compensated. Just wanted to mention this so nobody goes into their 100F garage and starts charging an agm at 14.7v with a lab supply. See your battery's spec-sheet for temp comp.
The end of the absorb cycle is usually when the battery current is .03 * C. That would be about 210ma for a 7ah agm.
State Of Charge SOC voltage:
While the following test will tell you nothing about your agm battery's health or capacity, you can get an idea of how well your solar setup is doing. With NO CHARGE and NO LOAD, let the battery rest for 4 hours and take an open-circuit voltage measurement:
100% = 12.9 to 13.3v
75% = 12.6v (good cycle life)
50% = 12.2v (ok, but limits cycle life)
25% = 12.1v (try not to go here except in emergencies)
Dead = 11.9v (damage / dead)
The actual manufacturer's spec may differ a little bit, but this is a very close ballpark.
With a good quality battery, you can discharge to 25% SOC hundreds of times. The issue is making sure you charge the battery soon after as it is leaving it in this state that really does the damage.
