Re: Solar power for charger
Hey sorry if this is the wrong place,
So I have this charger:
http://www.amazon.com/gp/product/B004AWE2L2/?tag=cpf0b6-20
and I noticed it has a power input of 12v 1a which is 12w correct?
Since im looking for a portable solar charger would I need one that has an output of 12w?
Also are there any or is it ok to under-power the charger?
Thank you for your time.
That looks like my Xtar WP2 II charger that I use with a solar charging system.
The problem that you'll have is, is that by going straight from a solar panel to that charger, you'll have erratic voltage swings. Assume that you have a 20w 12v panel. That panel can have an open voltage of ~15v-22v with no load and that might wreak havoc on your Xtar charger, possibly burning it out.
Some here fell that unless you want to be there for a month, charging at 300mA, you'll want a starting point of 20w. The 10w foldable panels output about 600mA on a laboratory test bench, so less in the real world.
What you really want to do is get something in the 20w range for panels, either two 10w panels daisy chained together, or a single 20w panel. You'll then want to get a digital solar controller, that acts as a buffer between your panels and your load, modulating/regulating the panel(')s voltage. Most of us run a 12v SLA/AGM mother battery in between and then charge off of that, back at home base.
The panels will send amperage into the controller, which will then charge the battery AND power the load.
Here's my setup from August of '12. That is the Xtar WP2 II on the bricks and you can see the small 12Ah mother battery there as well. The black thing on the white signboard is a Morningstar SS 10-L controller and that allows the 12v cigarette socket to get power from the battery, which is being topped off by the PV panels (2x30w.)
You can go smaller on the battery, if you want.
Here's the link:
http://www.candlepowerforums.com/vb/showthread.php?342073-Portable-solar-charging-setup-I-just-built
