If you desolder to bulb from the assembly, the $5 WA1185 is a direct fit.
Yes, and it's very similar to the stock lamp.Would the WA1185 still be over driven?
Is there any brighter bulb that would fit L1200? Something that would run on 3x IMR 18650 or 4x IMR 18500?
I know it's an old thread. How does one go about desoldering the bulb. On mine the bulbs pins are in the holes in the brass assembly. No solder at least on the surface. I could just try to pull it out but it's still good and don't want to damage it
