Got to sell some real throwers to gather fund for next mod.
All three Aspheric lights in the picture are for sale!
USA Only. PP Fee+Shipping: $9 for A & B, $15 for C.
If you want insurance, Add $3.
batteries are not included!
A.
Withdrawn. The #3 light in the picture, Aspheric mag 1C.
I believe it's made by Leaden, as the spec & structure looks just like this:
http://www.candlepowerforums.com/vb/showthread.php?t=161748
Spec:
For reference, Current Custom Job for mag cut down can be seen here:
http://www.candlepowerforums.com/vb/showthread.php?t=239209
Any color: $60 domestic (1C is same as 1D)
Extra services:
- Body/head grooving: $35 each
- Tail Cap mod - $25
A shorty host with finned head & bored tail cap will cost $120, just the host alone.
The lights has some flaws:
1, Couple dings on tail Cap:
2, A chip on the lens that's been repaired by Optical Adhesive Norland 61,
but you can still see a curved line. It does not affect performance.
B.
Second Light, the Mag 1C clone, #4 in the picture.
It served as a control light for this XPG build & recently upgraded to 1.5A drive current with bigger heat sink, some info about it here, it's the smaller one.
http://www.candlepowerforums.com/vb/showthread.php?t=264722
Specs:
There is no falws, never dropped etc. Asking only $55
C.
The One & Only, Franken MagDEFT I just finished here,
A marriage between Mag LED body & DEFT Head with 3" Aspherical Glass lens. Powered by EXtreme Top bin SSR-50, 57K Driven to slightly over spec
~5.5A using 2x 26650 IMR on Dual P7 driver in parallel.
http://img695.imageshack.us/img695/9038/img0611x.jpg
A.
Spec:
- Titanium Gray Color
- Cree P4 Direct Drive, Glow expoxy around the led.
- Tint appears to be Neutral white
- Aluminum Heat sink
- Surplus shed 52mm Aspherical (No longer available)
- Mag Cut down re-thread to 1C
- Finned head
- 18650 battery tube
- Recessed spring to run 18650
- Tail Cap step-bored to accept mag C spring for C-lion
- 1 Meter Lux 52500 using Dx meter, actual lux ~ 1.2-1.4x more.
Extra services:
B.
Specs:
- Mag 1C clone in Titanium silver color
- DX 50mm Aspheric Lens
- Custom Aluminum Heat sink
- Cree R2 driven to 1.5Amp on 1x 25500 DX Li-ion
- The tail cap is modified with 8x2 Ohm resistors in parallel to limit DD to 1.5A. Do not Run it without tail cap. Amp without tail cap is over than 2 Amp, will poof the led.
- Unlike the Mag 1C, this light is not focusable.
- The lens is held together bay a Rubber spacer,when screed the head in. be careful & don't let the lens fall out if you unscrew the bezel.
- Actually much smaller than the Mag 1C, but throw further.
C.
- Greater than 1300 emitter lumens
- Greater than 115,000 Lux at 1 meter
- Greater than 2x 1 meter lux of the stunning ARC Mania X6
- Out Performs the SR90 (SST-90 on 4" SMO) search light slightly in throw.
- Similar throw as DEFT FTP but with 5x the hot spot area, thus more useful as a search light.
