desert.snake
XP-L HI ~4000K in copper pill
the driver works fine, the heatsink is good
BitZ Driver [ https://www.candlepowerforums.com/v...Review-The-BitZ-Excellent-EDC-Light-(Updated) ] ::
Sold $ 75 including international shipping
Driver and Brightness levels, Hidden Signals - by maker
• BitZ Pocket use high efficient Buck-Boost converter and it will control power to the LED even though you use 3.6V rechargeable Li-Ion battery. So, LED will not be damaged by unregulated high current from Li-Ion battery. Off course, birightness by regular 3V CR123A and 3.6V rechargeable Li-Ion battery will be same.
• Input voltage range : 1.8V ~ 5.5V
• There are basic 3 Brightness levels (High-Medium-Low) and hidden 4 Signals (Strobe-Locater-Extreme Low-S.O.S.)
• Current to LED (tested) : High (500mA), Medium (150mA), Low (30mA)
• Basic 3 brightness levels has Memory Function. You will get next level by Off and On within two seconds.
• You will get into Signals by consecutive 8 On and Off. No memory function for Signal.
• Locater signal : useful mode for tracking and camping as "follow me" signal or location signal.
• Extreme Low : This mode is useful as a overnight candle at tent. Current to LED is 10mA.
