Burnt_Retinas
Re: Interest for MiniHID Li-Ion rechargeable solut
Ahhh, nice to see the list is being managed responsibly by each person who expressed interest and you are nicely looking out for each other /ubbthreads/images/graemlins/smile.gif I will lock-in the quantity from the list in a couple of days so I can plan what parts are needed to fill the rest.
I had too many uncertain expressions of interest and quantity during the initial phases as I progressed through the initial concept to design of working model to be certain. You can obviously look after yourselves with the list so keep it up.
Progress...
I have all parts including power supply boards to begin the first batch with the only exceptions being the fibreglass laminate for the ends of the holder and the boost regulators. Modamag has worked double time getting the IC's in real quick time and now he's working double time again to get the rest covered /ubbthreads/images/graemlins/smile.gif. May take a couple of weeks though, so please be patient - it's out of our hands and up to the suppliers. The IC's for the first batch should be here next week and I am expecting the PCB laminate routed just right to be here next week also.
I thought the LT IC solution would be a lot longer coming but it seems it's closer than thought /ubbthreads/images/graemlins/grin.gif.
BTW, a thought for you to consider....
There is a 3A fuse to the circuit. This is because I personally am concerned about any electronic item being left connected potentially unattended to a high energy source like Li-Ions . None of the converters I know of out there including the very popular badboys, madmax and many others do this without a fuse and there have been no problems. I'm just safety conscious.
This needs to be considered as if you intend to connect this to a high powered incan or short the output as you tinker with it (if you do) the fuse may blow due to low cold resistance of the incan filament or a short. If you intent to tinker, best you add the option - no fuse. If you use it for MiniHID only, I recommend leaving the standard option of having the fuse left there.
Be warned though; no fuse means that if you short the output or massively overload this you may damage the diode or inductor that is connected between input and output of boost converters. Not just this one, but any I have seen offered here on CPF.
If you are MiniHID only, go the standard fused circuit. If you are a tinkerer or want to experiment with 10W+ incans then specify no fuse, but it's your risk and I accept no responsibility for the consequences.
Chris
Progress...
Chris
