Sold/Expired SOLD: SST-90 1.25D 6.6Amp shorty >1500 lumens
ma_sha1
CT, USA
Up for sale, is a SST-90 Mag 1.25D shorty.
Specs:
Mag 2D cut down to Mag 1.25D for running 1x26650 4000maH IMR
Self cut re-jointed as seen in this Mag Dragon thread, post #36:
http://www.candlepowerforums.com/vb/...=280670page=2
SST-90 was directly soldered on a copper pad, then mounted onto HAIII Heat sink with 1 copper plug as seen here:
http://www.candlepowerforums.com/vb/...d.php?t=301857
The Reflector used is OP sputtered Mag OEM reflector, which gives beautiful beam and throw batter than most OP metal reflectors.
Resistance mod into both mag D switch Mag D tail Spring
1xIMR 26650 pulls 6.66Amp freshly charged. 1500 lumens
Copper contact pad for Mad D switch on battery positive end
Direct Drive, no driver to burn out, Run time ~ 1hr.
Battery spacer included, but not the battery.
Large hot spot with smooth transition to spill
Simple--Compact--Powerful--Long run time --Bullet proof.
Asking $195
PP fee/Shipping Add $15. USA only.
If you want a IMR 26650 to ship with the light, add $12.
Keep in mind that a Mag 2 or 3D cost $16 at home depot,
a Mag 1.25D shorty will cost $65 if you get it done by custom cut.
This is a steal for such compact powerful SST-90 Mag mod.
