Dark Laser
Hi there,
I plan to revive my old 6C with some serious incan power. Well, here are my thoughts:
- the light will probably be used in "mid power mode" most of the time (30-60Watts); show-off-bulbs cranking out luminz and even more luminz and low-output-bulbs are mostly for kicks (not said that I don't like those advanced options )
- I tend to use 4 A123 26650s because I like the flat discharge curve (maybe 4 18650 IMR cells, but then I might not be able to play with some particular bulbs), though I have no dedicated charger yet. I could probably mod my current charger with some diodes not sure if I like this idea or not.
- I will be using a stock Mag size KD SMO aluminium reflector, nevertheless I want to have a bulb that can achive a good throw with it. However, I understand that it won't beat dedicated LED throwers (e.g. XP-E Maglites). Will the 64610 be better for throw than other bulbs in this lumens class?
- low-resistance MOSFET switch w/ some sort of soft start, resistance mods plus inline fuse just in case(?)
- the light should be capable of destroying every other light I have in terms of raw output (well, this should be not that hard; my brightest is a dual-XM-L Mag 2C)
So, what do you think about a 4x A123 + 64610 setup vs. 4x A123/IMR + IRC bulbs (perhaps even 5x IMR if it is possible to stuff them into the Mag)?
Well, I'd like to hear completely different suggestions too if there are some
Thanks in advance :thumbsup:
